Operating the hood, engine on or engine off?
- Magicarcher
Do BMW make any recommendations on whether the hood shut be lowered with the engine running or just ignition on without engine running?
I have had some ECU undervoltage warnings, the car battery charge indicator is fine and the car starts fine so I am wondering if it is operating the car hood without the engine running (which I do quite a lot) is a factor.
Does anyone know how much current the hood motor consumes? I would not have expected it to be that high.
Does anyone else power the hood down without the engine running?
Z4 3.0L 2005. Titan Silver. Audio Upgrade Second Stereo Pioneer X8700DAB, Sony Xplode 4 x 70W Amp, 6.5" Reckhorn Subs in rear cubby, Focal AS165-3 in fronts.
- Smartbear
I usually have the engine running when operating the roof, but with a healthy battery it should be fine.
How old is your battery?
e85 3.0si sold
- Rusky
If you are operating the roof alot off the battery and only doing minimal driving then you are probably going to take out more than you are putting in i would have thought.
3.0l Silver SMG, whippy and ginge fringe/ Sound gen mod/ Media bridge fitted (bluetooth and audio streaming) / Clear third break light/ Hard Top/ Eibachs springs and DLV back box/ Roof motor in the boot/ plus lots more.
- tug
Always open and close mine with engine off via Gap Tech. Never had any problems.
Cheers, tug
Cheers, tug
E85 N46 2.0i SE BLACK SAPPHIRE
- Magicarcher
I don't know the pedigree of the battery it was on the car when I bought it. The car cranks with no problems.
I use my z on average 4 days a week and drive approx 50 miles per day, two 45 minute journeys. I never drive the car less than 10 miles, if I have a short journey to make I use my Mini.
The problem I am having is an airbag warning which intermittently comes and the code is "undervoltage"
I am suspicious that the first time it occurred was at work. I had parked up in the morning and on that day accidentally left my cigar lighter accessory (Video Camera) plugged in to the annoying permanently hot cigar lighter. I then put the ignition on and operated my softtop before I started the car. When I drove off I noticed the airbag light had remained on.
- Smartbear
It seems zeds can be sensitive to a below par battery & throw up electrical gremlins, yours sounds weakened by the dashcam being left on and then the roof operation didn't help matters, I think most batteries have a manufacture date on them?
e85 3.0si sold
- Marlon
I usually have the engine running when lowering and raising, however sometimes I lower it from outside - press and hold down the unlock button on the fob (no GapTec or coding required)
Gone: 3.0si 2008 E85
911 997 Carrera S
- Bing
I know that the cig lighter is always live, but are you saying that it's always making the lighter unit hot even when you don't push it in to do so ? If so this could be your problem ? Not sure how you fix it though...
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
- Magicarcher
No by permanently hot I means connected to B+ rather than Aux, it does not get physically hot. I do find it a pain to have to remember to unplug it everytime i park!
- Ducklakeview
The roof motor draws around 9 amps, for the 8 or so seconds it is operating. To be honest, that's probably LESS than the car's systems draw when you first turn the ign on (fuel pumps, ECU and all the other things like heater control flaps and the like that move when the ign gets turned on) SO, unless the battery is pretty weak you shouldn't have a problem.
Mike
Mike
- Bing
Ok, understand now. As others have said, I open and close the hood using my gaptech with the engine off all the time - have done on both my Zs - and it's never had an adverse effect. I also used to have a blackberry and left the charger in the socket all the time and that didn't cause an issue either, even though it was always drawing a little power to light up the LED on the charger itself.Magicarcher wrote: ↑Sat Jul 22, 2017 9:26 amNo by permanently hot I means connected to B+ rather than Aux, it does not get physically hot. I do find it a pain to have to remember to unplug it everytime i park!
Could it be giving an undervoltage fault because an airbag connector is loose or disconnected ? I know it's unlikely as the connectors are designed not to come loose but you never know. Be a pain trying to find out which one it is though.
- Kingfisher
If all else fails ..... read the handbook! Mine tells me to run the engine while opening and closing the roof so I do ... unless I'm showing off with the fob from out of the car! ...
Dec 2014 ... E89 35is sDrive M DCT ... Red ...
- cj10jeeper
I operated mine remotely for a decade without it ever having issues barely ever with the engine running.
Your ecu is unlikely to be hood related, poor battery perhaps.
- buzyg
Never had an issue raising or lowering with the engine off. Not something I have thought about before, but I probably operate about 50/50 engine on engine off.
- Magicarcher
Given there are a number of people who operate the hood with the ignition off, this is unlikely in itself to cause a problem. The problem will occur if multiple factors cause the terminal voltage at the SIM to fail. The SIM appears voltage sensitive and I found some BMW technical documentation on the web which I annoyingly can't now find, that suggested a supply voltage of below 9V can cause an error to be logged (I can only assume errors are inhibited while the engine cranks because I would expect the system voltage to go below this value when cranking).
I am trying to find the motor in WDS but not getting very far (have found hood module power supplies and switches but not the motor itself). I am assuming it is not grounded itself but the hood module has the ground which is in the right rear quarter well away from the SIM ground at the bottom of the A post/footwell, so a shared ground is unlikely to be the cause.
Ducklakeviews point that there are a good many systems initialising when the ignition is switched on is interesting because if I operate the hood while this is happening and the terminal voltage of the battery is low at the same time, it might be sufficient to cause the voltage to go too low.
I am coming to the conclusion that short of connecting a real time voltage tracer across the SIM I am probably not easily going to find out what is the cause and given it is an intermittent problem even this may not yield conclusive answers.
