Brake pad recommendations?
So the orange pad warning light is on
What's good in brake pads at present?
For an E85 2.5Si
Online ideally
For an E85 2.5Si
Online ideally
Z4 ‘13 20i Mineral Grey
Z4 '07 2.5Si Montego Blue
- Ducklakeview
Watching this for suggestions myself. .
Mike
Mike
What is your criteria for the type of pad are you looking for?
Standard road pad, with instant bite?
Full race pad that works well after repeated heavy braking?
Cheapest pad you can find?
Or something inbetween?
- Twin Turbo
Would I also add - normal brake dust or minimal brake dust?
- kis
I'm for better performance than OEM. Not worried about dust... but if it's ridiculously noisy then that would be a no-no.
Yellowstuff pads? Stoptech? Be nice to hear other people's opinions / recommendations
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
ATE do ceramic pads available at ECP, quiet, no dust and work really well.
2004 E85 Z4 2.5i SE Sterling Grey.
I'm looking for road pads not race so instant bite, minimal noise, don't care about dust, happy to pay more but not silly money
- Ewazix
I've posted this elsewhere after some research when I was changing pads. I went with Textar epads high-ceramic content lower dust. They feel like oem but any dust that comes off is light and not full of the burnt iron that is the cause of the rock hard cake others can produce.
Textar are an OEM supplier for BMW (Textar are actually part of TMD who also make Pagid and Mintex)
Jurid are part of Bendix and make after-market OE Quality brakes. ATE (Part of Continental Tyres) again are after-market OE quality.
Euro regulations prevent any pad sold for road use performing by + or - 15% differently to the original specification. So as long as it's a genuine Euro-stamped make there is little chance that you will actually detect a difference in performance between different road spec pads, and any improvement in one area of performance usually requires a compromise in another e.g. fade Vs initial/cold bite. So in slightly simplistic terms gaining 15% improvement in fade probably means sacrificing 15% in cold bite (choose running out of brakes on a hill Vs in to the back of your neighbour at the first junction )
But durability isn't the same as performance and some aftermarket brands have reports of material breaking-up or coming unglued from the back so it's worth doing a search before spending on supposedly 'up-rated' pads (check out ebc break-up complaints). But you can't go wrong with any of the big names and despite everybody swearing X is better than Y I doubt an average road user can tell any difference between them in a blind test (I emphasise this all relates to road legal spec pads)
Euro ECE R90 aftermarket brake specification regs http://www.unece.org/fileadmin/DAM/tran ... r3e_01.pdf
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
Thanks where's a good place online to get Textar?
- Ewazix
I think I got mine from Car Parts For Less who seem to be part of EuroCarparts but generally cheaper even without the ECP discounts. Although it doesn't look like they have the Textar E-pads in at the moment just the standard ones (which are still excellent but a lot cheaper).
Fiesta Ecoboost
Fiesta Ecoboost
- kis
Lots of the things I've read always lead back to OEM (Textar, Jurid, Pagid). Still undecided...
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Also have e-pads, happy with them so far, not tried on track yet but perfectly fine on the road.
Thanks do I just need the pads and new wear indicator? Nothing else required?
- Ewazix
If your warning light came on then yes you need a wear indicator (One per axle i.e. one for the front, one for the rear wheels). and some copper grease or similar anti-squeal for the backs of the pads.jamesgarbett wrote: ↑Wed Jul 19, 2017 12:57 pm Thanks do I just need the pads and new wear indicator? Nothing else required?
Whilst you are in there check the discs for heavy grooves or a deep wear lip (I tend to replace discs with pads either every set or two sets depending how they look). Also the wear pattern on the pads which can diagnose other issues, a really simple guide to pad wear here
> https://www.knowyourparts.com/technical ... ear-chart/
A torque wrench is needed as well.
Wheel bolts 120nm / 88ft.lbs
Carrier bolts 110nm 81ft.lbs
Caliper slide pin/bolts 30nm 22ft.lbs
Fiesta Ecoboost
Fiesta Ecoboost
- kis
You may also want some brake pad paste (for the back of the brake pad)? Forget what it's called! I've not personally used copper grease here... but Ewazix has, so I've no reason to doubt you can
Also maybe some copper paste for between the alloy and the brake disc - hopefully makes it a bit easier to get off next time! (Sometimes they fuse slightly).
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
