as you can bend your body around the doorframe. so the top of your torso is where the window normally is?
What have you coded with Carly
there are third party carly adapters on ebay for Β£20. if it doesn't work i imagine paypal would sort you out with a refund.
- Ducklakeview
Try it, it DOES make it a lot easier to get in from a tight space.
Mike
Yes. I want thinking. Haven't had a roadster before. Clean forgot there was no
B pillar.
Call it a senior moment.
B pillar.
2007 3.0 Si
Montego Blue
Manual
Montego Blue
Manual
Hi all,
I have a 2007 BWM 2.5si Sport
In regards to Carly, what exactly do I need to purchase to be able to do code different options for my car ?
Regards
Mark
Regards
Mark
You need to purchase 2 things.
1. The connector that goes into the port in the car. From amazon
2. The app for your phone. From the App Store
2007 3.0 Si
Montego Blue
Manual
Montego Blue
Manual
Hi Tomsdad
Thanks for the reply, its all done via Bluetooth then, no cables needed then ?
I can only speak about mine. I have an iPhone. Might be different for android.
It's not done by Bluetooth but wifi. Wifi network comes from the adaptor
2007 3.0 Si
Montego Blue
Manual
Montego Blue
Manual
- philbo909
Checked carly's website last night, cable only for e85/86 on Android, but WiFi works with Apple. Bluetooth on e89
Sapphire black z4 coupe 135,000miles young
- pvr
Does Comfort Entry not move the chair? On mine, it moves the chair all the way back and when I put the key in the ignition, it puts it back in my normal position. But that is on a Porker ...Ducklakeview wrote: βWed Jun 14, 2017 11:08 amTry it, it DOES make it a lot easier to get in from a tight space.
Mike
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Chris_D
Lol, short arse.pvr wrote: βWed Jun 14, 2017 1:31 pmDoes Comfort Entry not move the chair? On mine, it moves the chair all the way back and when I put the key in the ignition, it puts it back in my normal position. But that is on a Porker ...Ducklakeview wrote: βWed Jun 14, 2017 11:08 amTry it, it DOES make it a lot easier to get in from a tight space.
Mike
*pat on the head*
- pvr
Dutch <> short arse
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Ducklakeview
No, have tried that one and it won't have it..pvr wrote: βWed Jun 14, 2017 1:31 pmDoes Comfort Entry not move the chair? On mine, it moves the chair all the way back and when I put the key in the ignition, it puts it back in my normal position. But that is on a Porker ...Ducklakeview wrote: βWed Jun 14, 2017 11:08 amTry it, it DOES make it a lot easier to get in from a tight space.
Mike
Mike
Worth getting pro, or does lite do the coding still?
'04 3.0 m-sport, heated m sport seats, tinted lights, 108's, AC Schnitzer rear wings, drilled + grooved discs, red stuff pads.
- Ducklakeview
