MOT Fail
MOT Fail
Oh balls its failed. basically the garage said its on the brake lines being corroded in 3 separate places.
so he's quoting a 600+ due to the amount of work getting to them, is this reasonable as it seems a lot
does anyone know where near Leicester is reliable place to get this done as the garage cant do it next week due to holidays and I need the car to be on the road.
I doubt its something I can do myself as getting access under the car is a ball ache. although if its simply a case of removing trim and replacing pre made bought lines then I would do it if I could.
failed reasons:
"Reason(s) for failure:
Offside Rear Brake pipe excessively corroded (3.6.B.2c)
Offside Front Brake pipe excessively corroded Rear (3.6.B.2c)
Nearside Front Brake pipe excessively corroded to Rear (3.6.B.2c) "
failed reasons:
Proud Whip owner
MOT Fail
Hi.
That is a ridiculous price. Absolutely taking the pi**.
i do this job all the time on z4's. Including mine.
Worst case scenario £260.
I know I am in Chesterfield (J29/30 of M1), but only 50 mins to an hour from you.
Might save you 340 quid.
Give me a call if interested.
Andy. 07833 967239
Andy. 07833 967239
MOT Fail
I got my brake pipes done last year by my indy and charged £400ish. I thought that was a lot, but apparently a bit of a bitch to fit - something about them threading up above the fuel tank or something I think he said (a bit of a mechanical retard me, so didn't have any basis to argue).
I have heard others mention that it's often only surface rust, so a good chance if you gave them a scrub with some wire wool and slap a bit of paint on them it may get through a retest without comment.
- kis
MOT Fail
Like mentioned previously if there's any dirt they won't wipe away to inspect. They'll just put it down to corrosion.
Trip to Andy sounds like a good idea. Then best case Andy can revive them for you, worst case fit new pipes.
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
MOT Fail
Fitting over the rear axle/suspension is tight but really no problem at all.
Can reuse all the old clips and look nice. Then sprayed down with anti -corrosion coating so it NEVER happens again!
- Ewazix
MOT Fail
As a matter of interest what spray coating do you use?andyfanshawe wrote: ↑Thu May 25, 2017 3:51 pm Fitting over the rear axle/suspension is tight but really no problem at all.
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
MOT Fail
That's taking the piss, you could re plumb the whole car with Aeroquip lines for less than that!
Rules are for the guidance of wise men and the blind obedience of fools - Colin Chapman
MOT Fail
Its the one that stagecoach buses use to coat all their vehicles. Ill try and find a link to it. Used it that often I cant remember what its called!!Ewazix wrote: ↑Thu May 25, 2017 4:03 pmAs a matter of interest what spray coating do you use?andyfanshawe wrote: ↑Thu May 25, 2017 3:51 pm Fitting over the rear axle/suspension is tight but really no problem at all.
Will pop down to my workshop later and find out.
Good stuff but smelly!
Andy.
MOT Fail
yeah, i've just collected it and they said its just the labour. so i would have expected it to be a buy new ones from bmw and fit but they indicated they would be made to measure from a copper roll... seems a bit old school to me. I would have at least expected some sort of standardised part to be available.
Proud Whip owner
- Ewazix
MOT Fail
Cheersandyfanshawe wrote: ↑Thu May 25, 2017 4:31 pmIts the one that stagecoach buses use to coat all their vehicles. Ill try and find a link to it. Used it that often I cant remember what its called!!Ewazix wrote: ↑Thu May 25, 2017 4:03 pmAs a matter of interest what spray coating do you use?andyfanshawe wrote: ↑Thu May 25, 2017 3:51 pm Fitting over the rear axle/suspension is tight but really no problem at all.
Andy.
Fiesta Ecoboost
Fiesta Ecoboost
- cj10jeeper
MOT Fail
Did mine for the price of a brake flaring kit a few ends, litre of fluid and a roll of tube. Probably worked out at £50 all-in. Rear is a pita, for anyone without a little creativity, but do-able. Garages ramp up the price as they claim a need to remove the fuel tank, but not required
Personally I would not waste time trying to clean and coat them. These cars at 10-15 years old and if they are rusted then replace as failure at high speeds not what you want
MOT Fail
Totally agree if they are worn then I'll get it fixed. The car is 13 so probably worn enough.unfortunately I'm not in a position to do it myself so kind of happy to get it done by someone so don't mind. It's a shame as I kind of want to do it for the challenge... last yr was rebuilding my engine in another car. But I can't afford to have the car off the roadcj10jeeper wrote: ↑Thu May 25, 2017 7:28 pm Did mine for the price of a brake flaring kit a few ends, litre of fluid and a roll of tube. Probably worked out at £50 all-in. Rear is a pita, for anyone without a little creativity, but do-able. Garages ramp up the price as they claim a need to remove the fuel tank, but not required
Proud Whip owner
- Mr Tidy
MOT Fail
My 52 plate E46 Compact had an advisory for surface corrosion on the rear brake pipes when MOT'd just before I bought it in 2014 (but not in 2015 or 2016)?
My BMW indy said OEM pipes go over the top of the fuel tank, so it needs to be lowered (not removed) to replace them. Maybe the OP was quoted based on making pipes up as you don't then need to route them over the tank!
Sorted mine in April when I swapped the winter wheels back to summers with a wire brush, emery cloth and a tin of Hammerite for £6.99!
But if severely corroded a trip to Andy looks like the answer!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
