Geezzz everyone needs a rest!!!
Monkey mans power adder
- Machine monkey
- Machine monkey
Ok so I have had a few busy weekends working on the car. Had a massive low point!!! I seem to have supplied the turbo with far to much oil pressure.. the symptoms when we had the turbo running it was not producing much boost. And was not spinning up as exspected! Plus when I came back to the workshop a week later all the oil had pI$$ed on the floor!! After closer inspection the massive sir clip holding the impeller housing to the core had slipped out of its securing ring! So massive bad news!!!
Well I thought that as all my reading about turbo oil seals said it needed them replacing and doing by a pro. No problem replacing them but balancing a turbo needs special equipment! So I called the company where I got it from. And they asked is it a Garrett I said no .. A Borg Warnner? No... is it by chance s holset? I said yes. Well good news just strip it clean it it will be smoky but we doubt it will be damaged!! YAY the advantage of buying stuff designed oringanly for for farm equipment!!
I also had the time to strip and check the oil feed system. Took it all apart cleaned it modded it. I now have 2 in line gauges a better valve and a -3 not a -6 line feeding the turbo. So once all connected and with the engine not running. I can start the pumps with no pressure to the turbo and increase until I get no more than 70psi. And apart from bolting things back on wiring gauges and a small amount of ECU wiring it's done as far as I can take it.
I think one more 12 hour day!? Witch means 2!!! Then it's rolling road time.
Thanks forum would not have been possible without you lovely lovely people.
- MrPT
That sounds "exciting", at least. Glad to hear it can be rescued.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Machine monkey
We are not 100% it will be ok but very unlikely if I have.
And yes very excited can't wait to drive it to the rolling road!!
- Bradman
Awesome project... I'd given up on the turbo idea as I didn't like how the steering column got in the way of usual M54 setups, and was heading towards using an SC14 or something like that (needs to be cheaper than an ESS for my budget unfortunately). Very cool - I hope all goes well on the rolling road!
- mr wilks
all good news Mat , pics + vid clips when its rollingMachine monkey wrote: ↑Thu Jun 22, 2017 9:08 pm We are not 100% it will be ok but very unlikely if I have.
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- GuidoK
I want to see more pics/vids from the build!
- Machine monkey
Sure thing Andy.mr wilks wrote: ↑Thu Jun 22, 2017 9:35 pmall good news Mat , pics + vid clips when its rollingMachine monkey wrote: ↑Thu Jun 22, 2017 9:08 pm We are not 100% it will be ok but very unlikely if I have.
- Machine monkey
I am sure you do. But I am keeping cards fairly close to my chest for now! Just incase it all goes really wrong. I am quite sure 3-350 Bhp will be made. The limiting factors being plenum and injectors.
- srhutch
- Moderator
Yes just hope it's a bit more than 3 Matt
- Machine monkey
i am fully confident of that!!
- Machine monkey
There is room for a turbo in under the bonnet. But all the turbo kits are for LHD cars. So you have to either yourself or get one custom made. I think my costs are half of what the ESS would have cost with change. And hopefully similar power as there entry kit. There is also so ,much more potential with a few other mods later on I think for the price of the standard ESS kit i could get this set up close to 500bhp.Bradman wrote: ↑Thu Jun 22, 2017 9:29 pm Awesome project... I'd given up on the turbo idea as I didn't like how the steering column got in the way of usual M54 setups, and was heading towards using an SC14 or something like that (needs to be cheaper than an ESS for my budget unfortunately). Very cool - I hope all goes well on the rolling road!
Coming along well Matt, can't wait to see it tearing up the road, keep up the good work
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Chris_D
Keep going mat. Ur passed investment gate stage 1. Next is concept proof gate stage 2. After that; whupping 911 ass at the lights gate stage 3. Ultimately realising return-on-investment and onto fulltime enjoyment gate stage 4....
- Vanne
Gday mate, just checking in and saying what pretty much everyone else is saying here man, great effort, keep at it, and bloody good job mate.
V.
V.
Powered by Severn Tuning
