S65B40 Swap into E86 M
Smartbear
Post by Smartbear » Fri Apr 14, 2017 2:28 pm
TomK wrote: Fri Apr 14, 2017 2:15 pm
Fishy Dave wrote: Fri Apr 14, 2017 8:45 am 8) Brilliant, thanks for sharing. Calling TomK
Haha, yes I spotted this a few weeks ago on zpost. Fantastic project and something I've been pondering for a while. I'd want to keep the M3 6Mt so any advice you can give for me on that op would be much appreciated!
Best of luck with it. :happyclap:
Im sure the op mentioned he was getting a 6mt figured out just for those who might be interested?
e85 3.0si sold
alekos911
Post by alekos911 » Fri Apr 14, 2017 2:29 pm
Lovely thread! Good luck with the build and keep us posted!! :driving:
Thank God who created man to create these cars :-)
(ps: Because I am trying to improve my fluency in English, please feel free to correct me whenever it's necessary)
TomK
Post by TomK » Fri Apr 14, 2017 3:05 pm
Smartbear wrote: Fri Apr 14, 2017 2:28 pm
Indeed, hence me asking... :)
Beedub
Post by Beedub » Fri Apr 14, 2017 8:01 pm
yesssssss.
don't get tempted supercharge it...... it'll be undriveable.
stevo///m3
Post by stevo///m3 » Fri Apr 14, 2017 8:41 pm
This chap has a fair set of cojones! Let's hope it all works out. Sounds like it'll be done by the end of May :evil:
Bit more adventurous than a two litre turbo... :wink:
Stevo
SOLD - '07 MCoupe-Sapphire Metallic-Imola leather-piano black
Previous: E36 Evo Vert
Current: ocean-going G31 estate
Insta: stevothecrab
Apollo
Post by Apollo » Sun Apr 16, 2017 4:02 am
Update time!
I dropped the exhaust to get more clearance and work out a better flowing system. As you can see in the first picture the S65 headers bolt up to the E46 exhaust system so all that is needed at a basic level is just rerouting and one can maintain the same flanges. Makes for an easier job.
Getrag DCT trans next to the S65
Time to pull this sucker out...
Let's compare...
It does appear the DCT is a tad longer. Shouldn't be a problem.
The next challenge to work out is figuring out how to do all my hosing and tubing for coolant, AC, powersteering etc. I've come up with what I believe is a really simple and great idea. Retain the stock fittings but weld on AN connectors to run custom hosing. The pictures should explain this further. I'll have these done before next week is out.
Material removed
All the connectors
I will have to remove the heater core to take by my welder to have the connectors fabbed up
Inventory time
Everything labeled
Getting the DCT trans into it's seating position
Getting a spare S65 block into position to see how it lines up with the trans and subframe and rack
Obviously nothing is perfect fitment here but we are only going for ballpark estimations right now. I still need to look at my headers before I build engine mounts
Everything is high enough to not cause any safety issues
Here is how the trans mostly fits. You can also see why I have to relocate the heat exchanger
I'm looking at getting the E9X condenser and deleting my drier bottle from the Z4. The E9X condenser has a built in drier so there is no need for the bottle which would free up some room in engine bay.
2007 Black Sapphire Metallic + Imola Z4 ///M Coupe
S65B40A Swap, DCT, Apex ARC-8, GC Coilovers, H&R Sways, 996 BBK, Straight Pipes
2011 Space Gray + Fox Red ///M3 Coupe
ESS VT2-650, PSS10 Coilovers, APRacing BBK, Recaros, CF Roof, GTS DCT Tune
Chris_D
Post by Chris_D » Sun Apr 16, 2017 9:23 am
Awesome update.
This has to be the most compelling thread on the forum at the mo!
:thumbsup:
Scooba_Steve
Post by Scooba_Steve » Sun Apr 16, 2017 9:59 am
Amazing work.
kis
Post by kis » Mon Apr 17, 2017 10:55 am
Great build thread! The very best of luck with the rest of the project and I'll continue to follow with interest! :thumbsup:
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
enzed4
Post by enzed4 » Mon Apr 17, 2017 12:00 pm
Subbed. Awesome build so far :thumbsup: :bow:
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
Apollo
Post by Apollo » Fri Apr 21, 2017 5:24 am
Doing a swap with a manual car makes this a thousand times easier. I would encourage manual over DCT unless you want something truly unique. With a manual you can use your same original gauge cluster, clutch pedal and lines, and you don't need to run wires and things into the car and splice harnesses. The only wiring is in the engine computer box to get the MSS65 DME wired up.
Update.
Got the Z4MC driveshaft out and compared it with the DCT driveshaft.
Packages have been coming all week and will continue for a few weeks. I ordered the E9X AC condenser because it has a built in drier to save space in the engine bay so I can delete the E46 style drier bottle. I picked up a 19 row Mishimoto oil cooler for the DCT trans (It's way bigger than it looks) and I picked up the CSF Racing Engine Oil Cooler from the E92 M3 as it's the best size for the money it seemed and I wanted the inlet and outlet pipes on opposite sides otherwise the E46 M3 one was attractive. I decided I will retain the stock PS radiator as it does a swell job and is very large. Coolant radiator is in the mail. My wallet is starting to feel lighter after some of my orders this week. We have about $15k worth of items heading in the next couple weeks.
I like to take pride in the builds I do and a BIG part of that, probably the biggest part for me anyway, is having a clean swap. I cannot stand grime or dust left in anything! I had to tear down the exterior of the engine and get her cleaned up. My OCD is killing me!
I'm taking this time to do all the gaskets and get my AN fittings welded on the PS pump, AC unit, and OF housing.
First step was to seal up the engine.
I took the headers off to get in the outlet ports and clean some of the debris out.
Cleaning out the valley of this beast was tricky. It dawned on my to flip it upside down and hit it with a powerwasher after letting it soak in brake cleaner.
Up next was dropping on some of the first goodies I did up earlier on.
I called it quits for this day and got her tucked in for bed
Next day I got her prepped for my new rod bearings I ordered. After the S54 I am not taking any more chances.
More to come soon.
Machine monkey
Post by Machine monkey » Fri Apr 21, 2017 7:52 am
This is a really nice project.
Having done a Lexus v8 swap into a Toyota supra fairly recently. I know and agree on the benefits of having an aluminium v8 in place of cast steel straight six. We did virtually the same swap you’re doing but with Toyota bits. So i know how much $$$$ and time this will take up. All the very best to you buddy and keep the updates coming
My little blue zed is in lots of bits. With lots of things started and not many finished! I may have found the limits of my time and ability!!
Yorkie Z
Post by Yorkie Z » Fri Apr 21, 2017 3:13 pm
I can't believe this has only two pages of comments so far.
I love your attention to detail. In a perfect world you'd be my next door neighbour and Keira Knightley on the other side :rofl:
Keep up the awesome work :thumbsup:
A Dirty M///
Darkangelv2
Post by Darkangelv2 » Sun Apr 23, 2017 8:35 am
Not a lot to add. Love watching the progress and will look forward to each update as they come!
BMW Z4 2006 2.5SI - 437M Wheels - Strut Brace - H&R ARBs
3.0si Brake Conversion - Custom Nappa Sport Interior - Z4M Bumper+Bonnet -
BC Racing BR Coilovers - AFE Stage 2
Artful-Bodger
Post by Artful-Bodger » Sun Apr 23, 2017 8:04 pm
There's some serious thought going into this, :thumbsup:
Rules are for the guidance of wise men and the blind obedience of fools - Colin Chapman
