Storing a car for 2 years
- Silverzedtom
I'd also get the brake fluid changed. Two year intervals anyway, and any water that has been absorbed into the fluid will cause corrosion.
E85 2.5si
F55 Cooper S
F55 Cooper S
- Bing
Cool - thanks CJ
My bad calling it trickle charging - dangerously part-educated inexperienced non-tech layman at large
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
Personally I wouldn't jack it up, the bushes are designed to have the weight on them at standard ride height not to support the wheels hanging off them, pump up the tyres to prevent flat spots.
E85 3.0
http://www.southerncarstorage.co.uk/car-storage-rates
what about this 320 sounds money well spent although im not convinced by the 1/4 routine. but something similar
Proud Whip owner
I have had a battery removed from a car for 6 years connected to one of those solar chargers you can get from ebay for about £12. And its perfect.
Storing a car is a science in itself.
There are many web sites around that cover it far better than anyone of us here can.
No substitute for driving it occasionally though. No matter how well its stored.
Fuel pumps don't like sitting for too long.
Anyway, so much expertsie out there for long term stoarge........
- buzyg
This explains why you spend so much time in Holland. Or is that Walton.Chris_D wrote:'Overseas job for 2 years' and you couldn't get a trip back home in that time?
Come on OP, fess up you're really bein sent down for a bit of porridge aren't you? lol
Say awoight to Rolf Harris for us
- Chris_D
Bwaaahaha. Its HMP Liverpool now, actuallybuzyg wrote:This explains why you spend so much time in Holland. Or is that Walton.Chris_D wrote:'Overseas job for 2 years' and you couldn't get a trip back home in that time?
Resurrecting this tread.
Overseas job is now go. Leaving in September. Looking at this place for storage:
http://universalclassiccarsstorage.com/index.html
Been in touch with them, about £160 a month all in. Am I mad?
There are cheaper storage providers but only by about £30 a month
Z4MC | Midnight Blue | Heated Champagne Leather | Nav | CSLs | Stromung | RPI Intake | Black Grill
- Paulr
I can use it for two years for you if you want?
If you try and take a cat apart the first thing you have is a non working cat.
Funnily enough you're not the first person to offer that service
- buzyg
Two years is too long to come back and every thing just work IMHO. A few points in no particular order..
You can tax the car a month at a time. So only a few hundred quid to get it taxed and have some one use it a few times.
If you have a tracker fitted. That will likely drain your battery to dead as a dead thing in less than a month.
Use a trickle charger sparingly, as they can also kill your battery if simply left running.
Store the car somewhere dry. Not on someones drive or in a field out back. Obvious but worth a mention.
If you or a friend are able to run the car then the tyres should be ok. If not then take the wheels off and pop in on axle stands.
I agree on that. What I plan to do is when it's time to re-animate I'll have it transported to a BMW Specialist (TWG in Camberley) and get them to tickle it back to life. Then if anything needs attention it's in the right place.
- cj10jeeper
I would question if £4K is worth the spend, but that depends on how much you value it and if you will be back after 34 months. Few return on time
Separately you can leave a ctek or similar on all the time, not a trickle charger that is old school tech
