What have you done today?
Re: What have you done today?
Lucky, lucky you! Nowt but fog, dark clouds and drizzle up North
- buzyg
Work this morning then a drive up to Bude and spent the afternoon surfing in the Cornish sunshine.
- Marlon
Hard top's lookin good there Paul Saw several in the flesh on Sunday, I'm starting to like them.
Gone: 3.0si 2008 E85
911 997 Carrera S
- AlfaScozzesi
It'll be a coupe next Marlon!
- Paulj100
- Marlon
ha, they are beautifully designed but I'm too addicted to open top motoring.AlfaScozzesi wrote:It'll be a coupe next Marlon!
911 997 Carrera S
- ben g
Absolutely stunning Paul.
I spent my day in work 10:30am-10:30pm. Why oh why did I agree to do a 12 hour shift on a beautiful autumn day?
That looks ace!
- Mr Tidy
Not exactly strenuous but I put some GummiPflege on the door seals so hopefully the windows won't stick to them when it starts getting colder - oops, it was yesterday now if that makes sense!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Yesterday I had my new Uniroyals tyres fitted to the rear, what absolute pigs the old run flats are to get off, the poor guy at my local garage had a right job getting the beads to break away.
Today I changed the oil and filter, I just love this car, the little access cover for the oil drain plug, nice clean removal of the oil filter...sweet
I used Shell helix ultra professional 5w30, the old oil looked quite dirty.
I jacked the front up then sat the wheels on ramps then let the oil drain to a tiny trickle, I then lowered the drivers side on the jack, there was quite an increase in the flow of old oil. I do like to get as much of the old stuff out as possible, I bet most garages don't do that.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- TomK
Read the JE Turbo thread
?????TomK wrote:Read the JE Turbo thread
It's over 100 pages long, what am I looking for ?
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- MrPT
Good tip. You are right, it is a really easy car to oil service.firebobby wrote:Yesterday I had my new Uniroyals tyres fitted to the rear, what absolute pigs the old run flats are to get off, the poor guy at my local garage had a right job getting the beads to break away.
Today I did... not enough! Roll on tomorrow...
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
Changed all the springs, dampers, top mounts, drop links and anti roll bar on my Fabia VRS.
Having to drop the front subframe 4 inches to get the ARB out is a bit of a pain!
Pulled out the wiper motor today to try and sort out the annoying problem of the wipers stopping higher than they should, cleaned up the motor inside and out then gave the bulkhead area a good vacuum and clean before resembling, problem solved. Had a blueberry muffin to celebrate
