Types of auto gearboxes
Paulr
Post by Paulr » Fri Dec 15, 2017 11:51 pm
A Facebook conversation has me confused. As far as I know, there is the traditional old school auto gearbox that uses pressure and valves to operate, and the SMG, a manual box with an auto change instead of a foot operated clutch. The old school auto does not have paddles, the SMG does. Is that right, or can the old school box also have paddles?
Chap on Facebook says his does.
If you try and take a cat apart the first thing you have is a non working cat.
LordOxygen
Post by LordOxygen » Fri Dec 15, 2017 11:57 pm
Slusher autos can and do have flappy paddles to manually change gear. My current Honda and prior Mazda 6 are 2 examples.
Paulr
Post by Paulr » Sat Dec 16, 2017 12:01 am
Yes, but the does the Z4 one?
kis
Post by kis » Sat Dec 16, 2017 12:17 am
So far as I know pre facelifts never came with paddle shifts. The facelift ones did. And obviously SMG do as well.
I know cj10jeeper did the conversion on his Zed. So basically retrofitted the paddle shifts. I think DLV is or maybe has already do it too.
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
Ducklakeview
Post by Ducklakeview » Sat Dec 16, 2017 1:24 am
kis wrote: Sat Dec 16, 2017 12:17 am So far as I know pre facelifts never came with paddle shifts. The facelift ones did. And obviously SMG do as well.
It's on my list!
Mike
firebobby
Post by firebobby » Sat Dec 16, 2017 10:31 am
My auto does not have paddle shift. I can knock the lever over, to change the gears manually, but I just keep in in auto and flick the fun button on and off.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
cj10jeeper
Post by cj10jeeper » Sat Dec 16, 2017 12:00 pm
I agree - they added paddles post facelift as by then the idea was getting more popular.
It’s a straightforward conversion as the paddles do no more or less than replicate the effect of pushing the selector back and forth in sort mode
My write up is on here.
patriot66
Post by patriot66 » Sat Dec 16, 2017 3:35 pm
The SMG is not an auto gearbox. SMG = Sequential Manual Gearbox. It is the 6 speed manual from the 3.0i with a clutch but no clutch pedal. Electronics and hydraulics operate the clutch and select a gear when the driver uses the paddles or lever. It can however be put into full auto mode and driven just like a regular auto but quite frankly it is terrible in this mode. In SMG mode you have to operate the paddles or lever to change up or down. :thumbsup:
brightonbimmer
Post by brightonbimmer » Sat Dec 23, 2017 1:59 am
patriot66 wrote: Sat Dec 16, 2017 3:35 pm The SMG is not an auto gearbox. SMG = Sequential Manual Gearbox. It is the 6 speed manual from the 3.0i with a clutch but no clutch pedal. Electronics and hydraulics operate the clutch and select a gear when the driver uses the paddles or lever. It can however be put into full auto mode and driven just like a regular auto but quite frankly it is terrible in this mode. In SMG mode you have to operate the paddles or lever to change up or down. :thumbsup:
I agree that the SMG (7 speed as in my 2006 M6 V-10) is finicky, and often terrible. I keep trying the auto mode to see if it will learn to get better, but most often use the paddles to select up or down. Even then, one must ease off on the accelerator during the shift to make it smoother. Once cruising at highway speeds, I revert to auto mode and the up and downshifts are automatic and smoothly engaged.
David
Current cars: 2013 Honda Civic EX (daily driver, 55,000 KM) + 2003 Mazda MX-5 SE (Titanium Grey, with 22,000 KM) + 2006 BMW M6 (Indianapolis Red Metallic, just turned 67,000 KM)
First sports car was 1963 Morgan 4/4 in 1964.Image
Paulr
Post by Paulr » Sat Dec 23, 2017 11:36 pm
My Smart Roadster had the semi-auto gearbox with steering paddles for gearchange, and even my old 2002 Corsa had this SMG type ‘Easytronic’ gearbox, and if you learned how to drive properly it is was quite a really enjoyable drive. I miss the paddles on my Z4 with its slush box, would be nice if I can do a DIY type after market fit if it is not too much hassle.
