How to identify if my car has heated seats?
Hi
I have a 2004 3.0L SE which seems to be highly spec’d in terms of extras, including electric memory seats.
I’ve read several posts on the forum, and I believe that the wiring for heated seats is already likely to be present.
I wonder if it is possible that the heating elements Are also there, and I wonder if anyone can advise how to determine this? If they are there, is it just a case of me getting the switch panel and making a few connections?
2004 3.0i SE in titanium silver with clear third brake and side lights. Black interior.
M-Sport suspension, 18” 107 mag ellipsoids, ZHP, xenons, cruise control and stubby
- Wondermike
- Moderator
The heating elements won’t be there without heated seats.
Not unless a previous owner has evicted the switch panel, so noAla5dair wrote: ↑Mon Dec 11, 2017 7:01 pm Hi
- GuidoK
do a vin check.
if it wasn't installed at factory, the panels aren't there (to follow up on sticky's scenario)
- Yorkie Z
I identified my heated seats by the heat
Sorry couldn't help it. Soon be summer
A Dirty M///
... not sure whether to laugh or cry now, but thanks for the comments. VIN checker shows no heated seats, but it does show headlight cleaning system, which isn’t there, making me think that the front bumper has been replaced.
Nevertheless, thanks for the comments. I will now have to keep an eye open for some heated seats on the forum...
... Oh, and my car is Titan Silver ...
- srhutch
- Moderator
You should have two pumps on your washer bottle then if you car came with headlamp wash.
Just briefly, srhutch, as a very late follow up. Both pumps are there, as are the washers. Thanks. Operator error.
I didn’t realise that a) the washers only operate when the lights are on and b) even then, they don’t operate every time, just to quote BMW, “at appropriate periods”
- Silverzedtom
Probably once per ‘X’ washes. 5 rings a bell.Ala5dair wrote: ↑Tue Feb 06, 2018 1:27 pmJust briefly, srhutch, as a very late follow up. Both pumps are there, as are the washers. Thanks. Operator error.
E85 2.5si
F55 Cooper S
F55 Cooper S
Default is 5 but I find they operate first time, every time, on turning on the lights. It is also possible to turn them off, increase the interval and a few other things like spray duration.
Thanks, both. Yep, I found that they operate the first time the lights are switched on; my lights were on auto before, and this is what confused me. I’ve not determined what “x” is, but I’m not too bothered, just relieved that they are working, and it’s not another job to add to the list....
