So I'm looking at putting a single DIN head unit in as I cannot stand BBC radio anymore
In previous cars I've used a splitter like this https://www.amazon.co.uk/Autoleads-PC6- ... B00FRGBLIW but these don't work with an amplified aerial.
Is the aerial on a 2004 E85 amplified or not?
Also any recommendations for a fascia plate supplier.
Any help greatly appreciated.
DAB in an E85
DAB in an E85
I believe the amplifier is integral to the mounting of the aerial base in the rear wing, so you can't bypass it to get a DAB signal. I have a powered stick on DAB aerial on the inside of the windscreen of the Z4, used with a Pioneer DAB head unit. I've also used the same type of aerial successfully with OEM retro fitted DAB modules in E91 3 series and R55 Mini.
Chris
Chris
08 Z4 3.0si Sport Coupe in Montego Blue
DAB in an E85
Everything you need to know on my thread here. Includes links to the fascia adaptor and dab antenna I bought plus where I fitted it
viewtopic.php?f=2&t=99127&p=1450991&hil ... t#p1450991
DAB in an E85
Oops, looks like I didn't share the link to the antenna. Here it is...
Pioneer DAB Antenna https://www.amazon.com/dp/B00AGMB5QK?ref=yo_pop_ma_swf
- 99ron
DAB in an E85
I've got a DAB antenna in the boot - a magnetic unit stuck to the bottom of the boot lid. Work a treat. Great signal.
Might be this one.
http://www.dabonwheels.co.uk/Kinetic_Ma ... erial.html
Might be this one.
Z4MR E85 for sunny day Hooning.
Now with added joy of Gruppe M.
DAB in an E85
Thanks Greg, just what I need.greg81 wrote: ↑Tue Nov 28, 2017 5:10 pm Everything you need to know on my thread here. Includes links to the fascia adaptor and dab antenna I bought plus where I fitted it
I’ve put a wind screen mount aerial in the Evo but the reception is terrible. I think I’ll try the magnetic base on in the boot.
- Magicarcher
DAB in an E85
99ron, when you say stuck to the bottom of the boot lid, do you mean the antenna is pointing down into the boot?99ron wrote: ↑Tue Nov 28, 2017 6:35 pm I've got a DAB antenna in the boot - a magnetic unit stuck to the bottom of the boot lid. Work a treat. Great signal.
Might be this one.
Z4 3.0L 2005. Titan Silver. Audio Upgrade Second Stereo Pioneer X8700DAB, Sony Xplode 4 x 70W Amp, 6.5" Reckhorn Subs in rear cubby, Focal AS165-3 in fronts.
- 99ron
DAB in an E85
Yep. Exactly that. Stick it in the corner and it doesn't get in the way. Boot is deep enough for the short antenna. I had a windscreen antenna in an RX8 I used to run and it dropped the signal on some stations all over the place in a way this one never does. I'd take a pic but the Z is all wrapped up in the garage for the Winter.
