E85 one touch roof
E85 one touch roof
Apologies for a newbie question I’ve seen some cars advertised as being able to drop the roof off the key and one touch. How is it done, I’ve tried numerous key presses and nothing happens
- Smartbear
E85 one touch roof
Hi, one touch roof operation is enabled by fitting a roof module like gaptec, gives one touch operation from the dash buttons as well
e85 3.0si sold
- Marlon
E85 one touch roof
You should be able to drop the roof from outside with one touch without fitting a 'roof module' - simply press the unlock button and keep it held down, the roof should drop.
Gone: 3.0si 2008 E85
911 997 Carrera S
E85 one touch roof
That's what I was told, but it didn't work on my Zed Colin. I had to fit Gap-tec
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Marlon
E85 one touch roof
Interesting Fred I wonder if it depends upon the year of maufacture?
911 997 Carrera S
E85 one touch roof
- Wondermike
- Moderator
E85 one touch roof
I fitted the smart top module. Tried all different combinations on the key, nothing.
DaveZ4richardson
3.0i 2003 E85 auto cruise control, smart top module.
E85 one touch roof
Tried the press and hold technique but to no avail. Is the gap tech an easy fit?
- Smartbear
E85 one touch roof
Yep, it’s ashtray out & 4 or 5 wires to connect. Ps, get some proper terminal strip instead of using the troublesome scotchlocks provided
e85 3.0si sold
- Ducklakeview
E85 one touch roof
The car can also be programmed to allow you to raise and lower the roof by holding the lock/unlock buttons. Not as flashy as the Gap-Tech, but about a quarter of the cost. Other things can also be programmed at the same time, such as auto locking when you drive off, indicator flashes and/or audible chirps when locking/unlocking, passenger window one touch up (usually not enabled) and a few other options.
Mike
Mike
- Chris_D
E85 one touch roof
Weird. Mine drops via the fob and extended press of the unlock button and mine's an 03.
I did have a fiddle abart with Carly tho as it's an option in there to program it. Can't remember.
And Marlon, ur a Mod now? lolz. has u banned anyone yet? should i be afraid??
- Marlon
E85 one touch roof
Yep . . .Chris_D wrote: ↑Mon Nov 27, 2017 10:06 pmWeird. Mine drops via the fob and extended press of the unlock button and mine's an 03.
911 997 Carrera S
E85 one touch roof
Oh Collin, use your power as a mod and ban Chris, you know it makes senseMarlon wrote: ↑Mon Nov 27, 2017 10:59 pmYep . . .Chris_D wrote: ↑Mon Nov 27, 2017 10:06 pmWeird. Mine drops via the fob and extended press of the unlock button and mine's an 03.
You back to the mad house Mr D, how's the job going ?
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
