Fitted my chinese steering wheel cover
- Paulr
Looks great, took about 4 hours, some fiddly bits, but turned out nice!
If you try and take a cat apart the first thing you have is a non working cat.
I'm intrigued by these things. Where did you buy? I found a leather one £27 delivered from Wish
With all those dashboard additions, go on admit it.. your an Uber driver. lol
Alpina Roadster S LUX #030
- Paulr
Not quite, but I do use it for work a lot! You cant see the dashcam, it's hidden behind the mirror. And you cannot see the handsfree either! Getting myself a smart watch with phone capability so I will remove the phone holder if the phone/watch works out well.
I just found and bought one. Download the AliExpress app and search for "mewant Z4"
- Paulr
Beat me to it, that’s where I got it from.greg81 wrote: ↑Mon Nov 06, 2017 10:57 pmI just found and bought one. Download the AliExpress app and search for "mewant Z4"
- chapeau
How did you get on with tucking the leather behind the spokes. My spokes look incredibly tight around the existing leather on the wheel. Did you remove them to wrap it, and did you remove the wheel to actually work on it or do it in situ?
I ask as I am tempted to get one and give it a go.
E85. 2.5i SE. 2004. Sterling grey, anthracite 107s, black leather heated seats, hardtop, sound gen retrofit, matt black grills, stubby, zhp, cupholders retrofit, roof motor in boot.
- JINGLE
Exactly what I was thinking....chapeau wrote: ↑Mon Nov 06, 2017 11:42 pmHow did you get on with tucking the leather behind the spokes. My spokes look incredibly tight around the existing leather on the wheel. Did you remove them to wrap it, and did you remove the wheel to actually work on it or do it in situ?
- Marlon
Nice job
Its fitted something like this - is that right? involving sewing etc. looks fiddly as hell !
Gone: 3.0si 2008 E85
911 997 Carrera S
- chapeau
I believe so yes. I have watched the videos and have patience so am not deterred by the sewing but the spoke sections on a z4 wheel do not have the gaps like the wheels in the demo to tuck the leather behind.
- srhutch
- Moderator
It’s easy to remove the spoke covers. Can’t see how you could do a proper job without doing so.
OnlineUsel
I have done mine and the left and right spokes fit over the top but the bottom one does not. I thought that it wouldn't tuck in but it did quite easily actually. There is enough give in the original leather to provide enough gap.
This is quite easy to put on the wheel but it is time consuming so dont do it if you need the car the next day for work
If you have a standard wheel it is definately worth doing. It looks and feels so much better. I used the cheaper faux leather wrap.
- Sgr74
Remove the wheel and the plastics. Then do it sitting on your couch while watching the television and staying warm.
It’s an easy job. Just make sure you pull it tight together before stitching and follow the line of the original stitching.
Black 2.5 Roadie.
- Paulr
I kept the wheel on, but removed the plastic spoke covers, it is four screws to undo but it is likely to snap the bit where the screw goes into, as one of mine has. The covers snap back on and the screws should then tighten it all up and hold it all together. The broken one is just snapped on at the moment. Once I get a bit more time I will glue it back together properly, but to be honest you wouldn't really know and they don't just fall off without the screw holding them together.
All it needs is a bit of patience, but as was said earlier, start early in the morning or plan not to use the car the next day as it will take four or five hours.
