Splitting headlights..
- Ducklakeview
Ok, so I've seen all the "it can't be done" posts regarding PROPERLY splitting OEM lamps, BUT you now what I'm like when someone says it can't be done..
So, what have people tried?
Obviously the oven method is what I'm thinking, but Mrs DLV has just gone and bunged a chicken in it, the cheek!
So, in a couple if hours I am going to give it a go..
I'll strip as much as possible out of the lamp first, notably dipped beam projector unit, all bulbs and as much wiring as I can..
I intend to start with 100 degrees and go upwards from there if required, until I either kill the lamp or get the damn thing to split!
Wish me luck lol..
Mike
Wish me luck lol..
Mike
Pretty sure the plastic will melt before the glue loosens
I used a dremel
I used a dremel
- Smartbear
Don’t forget to remove it from the car first
e85 3.0si sold
- Ducklakeview
I’ve seen e46 ones split with a hot air gun before. 50s kid did it on YouTube.
2004 E85 Z4 2.5i SE Sterling Grey.
- Ducklakeview
Heat gun won't do these. It'll melt the edges before it gets the middle of the joint hot enough.MJJamieson wrote: ↑Sun Nov 05, 2017 5:33 pm I’ve seen e46 ones split with a hot air gun before. 50s kid did it on YouTube.
Mike
- JINGLE
Interested to see how this turns out.
On a separate note, you mentioned to me about the 2xcite lights as mine are LHD and you mentioned filing down the beam pattern to a flat edge (rather than it kicking up to the right currently) ..... do you think this oven method would work to split the 2xcite lights?
- Ducklakeview
Yes the sonar /2xcite ones split easily.JINGLE wrote: ↑Sun Nov 05, 2017 6:20 pm Interested to see how this turns out.
Mike
- patriot66
Hi MikeDucklakeview wrote: ↑Sun Nov 05, 2017 6:57 pmYes the sonar /2xcite ones split easily.JINGLE wrote: ↑Sun Nov 05, 2017 6:20 pm Interested to see how this turns out.
Mike
Have you split Sonar/2xcite lights then ? If so then how did you do it ?
- Ducklakeview
Ok.. So the consensus is that oem lights cannot be split without cutting the lens off, therefore removing in my mind the vital locating and sealing lip yes?
Well it can be done WITHOUT cutting the lens..
Sealing lip intact.. Mike
Well look at that it’s a miracle
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
- bony_13
I might as well be the first to ask for your full guide then Mike..... pretty please?
- srhutch
- Moderator
Looks like it’s damaged the black housing though.
- Ducklakeview
Power over skillDucklakeview wrote: ↑Sun Nov 05, 2017 8:44 pmThat was me trying to use brute force in an earlier attack..
Mike
Glad you've been the first to discover the proper method.
