So who has fitted a suspension kit recently
Car has a broken front shock so might be time to replace all four and springs , prob not doing coil overs so just shocks and lowered springs
Used Koni adjustables and eibhac springs to good effect on my Cossies so what’s the recommendation for z4s , I’ve a 2003 2.5 std
Not looking at spending big bobs as just a pair of front shocks will cover me technicilly
2003 2.5 silvery goldish
gaptech,19" ispiris,iPod kit,xcite halos,load of petrol
- philbo909
i got bilstein b4 shocks and suplex springs fitted on each corner this month and it's night and day. however everything was completely knackered so it's not a great comparison. but this is probably the cheapest decent option (parts in total less than £400)
the bilstein b12 kit is roughly £700, which is what a lot of forum members go for (eibach 30mm lowering springs included)
Sapphire black z4 coupe 135,000miles young
- MACK
Bilstein B4 with eibachs is another option folks have used and reported good results. Circa £450 for the springs and shocks.
Silver 05 3.0i SE
White E89 20i M Sport
- NickDE
Me toophilbo909 wrote: ↑Fri Oct 27, 2017 8:54 pm i got bilstein b4 shocks and suplex springs fitted on each corner this month and it's night and day. however everything was completely knackered so it's not a great comparison. but this is probably the cheapest decent option (parts in total less than £400)
Darkness gone, go Darknes2, go Frozen, go Tronic
I'm thinking about new shocks soon as well, I assume it's worth getting new top mounts at the same time?
E85 3.0
- NickDE
Yes, they're relatively cheap so not worth putting the old ones back in
So are the Bilsteins adjustable and what’s the spring drop
Any pointers on suppliers please
Tks again for the good info lads
- MACK
No the b4 shocks or b12 kit is not adjustable. If you want want adjustable the cheaper option is something along the lines of bc coilovers etc. Billys that are adjustable are well over a grand
Based on what you said about budget id go b4 with eibachs or the combined b12 kit unless you really need it to be height adjustable. The eibachs are just about perfect drop wise on the e85 anyway. If you go b4 you can pick these up for what non m sport sach can be had. The m sport sachs are dealer only and therefore stupid money. Most on here think the b4 are a superior product.
Silver 05 3.0i SE
Sounds like b4 and Sivakumar he is the way to go , just need to find a good deal now
- barralee
i am also going to change mine and found this tread useful , i would like to know if the ride height is dropped with this option as i have a steep drive and i cant go any lower need to keep the ride height normal (3.0 with m sport suspension 2004).So will i have to just go oem.
- MACK
The Suplex are standard ride height, but do make sure you get the correct M sport option for your car as they also do a standard version which would jack yours up 15mm.barralee wrote: ↑Sun Oct 29, 2017 9:45 am i am also going to change mine and found this tread useful , i would like to know if the ride height is dropped with this option as i have a steep drive and i cant go any lower need to keep the ride height normal (3.0 with m sport suspension 2004).So will i have to just go oem.
If you went for eibachs you would have a 15mm drop over your current m sport suspension.
Silver 05 3.0i SE
- NickDE
Phone Suplex UK to get the right part number. There are a lot of variations based on exact model, engine, transmission. They're nice people and will help you out.
Here’s what I need I believe
https://m.ebay.co.uk/itm/EIBACH-BILSTEI ... 1853384648
GOT A SACHS/EIBACH KIT FITTED NOW AND THE DIFFERENCE IS NIGHT AND DAY, STDS MUST HAVE BEEN VERY WORN.
EASY TO FIT AND GOT SETTINGS ADJUSTED AFTERWARDS, MIGHT PLAY AROUND WITH THEM THO....
ZAGA
ZAGA
caps on sorry
