Z4 E85 N52B25 performance upgrade
Darkangelv2
Post by Darkangelv2 » Thu Oct 05, 2017 1:20 pm
Smartbear wrote: Thu Oct 05, 2017 1:06 pm
Joycey wrote: Thu Oct 05, 2017 1:01 pm
Smartbear wrote: Thu Oct 05, 2017 12:54 pm
Sadly you’re not going to get 50bhp from an exhaust & intake change, I think the Dyno must have been fed magic mushrooms :roll:
A big thing in the states they love is buying our N52 manifolds, We have two disa's giving the higher bhp figures. They don't have them over there I'm lead to believe.
Even if it had ten disa’s it wouldn’t produce 255horses, we haven’t seen the Dyno print out yet?
If he's added the basics of a 2.5si to his engine he'll get to 218. So he's saying intake and exhaust mods with a flash has seen him gain 37HP. That's not beyond the realms of possibility is it?
BMW Z4 2006 2.5SI - 437M Wheels - Strut Brace - H&R ARBs
3.0si Brake Conversion - Custom Nappa Sport Interior - Z4M Bumper+Bonnet -
BC Racing BR Coilovers - AFE Stage 2
Smartbear
Post by Smartbear » Thu Oct 05, 2017 1:21 pm
Joycey wrote: Thu Oct 05, 2017 1:17 pm
The page before I posted the dyno print out.
I'll have to find the link of Zpost about the way the disa's work together with the valvtronic system to get all the extra.
I think your Dyno sheet shows a forced induction engine? I’m talking about the OP normally aspirated 2.5litre engine making 255bhp......
e85 3.0si sold
Joycey
Post by Joycey » Thu Oct 05, 2017 1:25 pm
Smartbear wrote: Thu Oct 05, 2017 1:21 pm
That's exactly what I'm trying to say. The print out shows a supercharger bolted to a 2.5. The OP asks about ways to increase power but thinks they don't make one for the 2.5 when ESS do. :P
Smartbear
Post by Smartbear » Thu Oct 05, 2017 1:27 pm
Darkangelv2 wrote: Thu Oct 05, 2017 1:20 pm
The OP says that intake & exhaust changes gave him 205bhp which means the ecu tune gave an extra 50bhp on a normally aspirated engine. That’s not realistic imho.
e85 3.0si sold
Smartbear
Post by Smartbear » Thu Oct 05, 2017 1:30 pm
By the same reckoning the 3litre n52 would be mappable to 315bhp or so, it’s never going to happen.
e85 3.0si sold
Scarp
Post by Scarp » Thu Oct 05, 2017 1:38 pm
Ok last time the principle is not the ecu tuning gave me 50 HP but the fact that the same engine is used in a newer model and for some reason the E85 has restrictions mainly in ecu. The ecu was completely reprogrammed it took a week of modifications dyno testing etc. This is normally not possible in atmospheric engines this was my luck that the same engine with some different parts has 160kw in a newer model of Z4 :)
Z4 E85 2006 2,5i 255 HP custom built
facebook: facebook.com/bmWhiteZ4
Youtube : https://www.youtube.com/channel/UC54mhx ... subscriber
Smartbear
Post by Smartbear » Thu Oct 05, 2017 1:41 pm
Scarp wrote: Thu Oct 05, 2017 1:38 pm Ok last time the principle is not the ecu tuning gave me 50 HP but the fact that the same engine is used in a newer model and for some reason the E85 has restrictions mainly in ecu. The ecu was completely reprogrammed it took a week of modifications dyno testing etc. This is normally not possible in atmospheric engines this was my luck that the same engine with some different parts has 160kw in a newer model of Z4 :)
It doesn’t though, 160kw is 214bhp, the e89 2.5litre produces 201bhp.
e85 3.0si sold
jamie_z4
Post by jamie_z4 » Thu Oct 05, 2017 1:42 pm
Smartbear wrote: Thu Oct 05, 2017 1:41 pm
maybe the 89 variant is different output in different continents Rob?
18 Z4s owned to date.
Current: 2.5i Titan silver
Smartbear
Post by Smartbear » Thu Oct 05, 2017 1:45 pm
jamie_z4 wrote: Thu Oct 05, 2017 1:42 pm
Possibly but the op has already said that intake & exhaust modes gave him 205bhp, something doesn’t add up here?
e85 3.0si sold
Scarp
Post by Scarp » Thu Oct 05, 2017 1:47 pm
what I saw in specifications mine has 130kw the E89 I think 2,5SI or something like that has 160kw dont know how its in US . Thats where we started to search the differences. The E85 has idiot made cat system :D So theoretically if you have stock E89 parts and soft on my engine it should generate 160kw . Same engines in bmw have different power output :) I looked at the 3 liter biturbo for my car and it has like 4 power versions
Scarp
Post by Scarp » Thu Oct 05, 2017 1:50 pm
and for the 2,5 liter there is no supercharger I contacted ESS like 4 times they only have a kit for the 3,0 . As far as I have researched for the N52B25 there is no supercharger available . I could install a shrick cumshaft taht would give me another 20-30 HP but thats more of a racecar mod then a normal usage fun car :)
The only sollution in my case can be swap to a N52B30 and supercharge it
Scarp
Post by Scarp » Thu Oct 05, 2017 1:54 pm
The power was measured on 2 different dyno´s a year on from the other
Both same resault :)
Joycey
Post by Joycey » Thu Oct 05, 2017 2:02 pm
Scarp wrote: Thu Oct 05, 2017 1:54 pm The power was measured on 2 different dyno´s a year on from the other
One supercharged 2.5 :driving:
This is the first E89 they've done so might not be on the market yet.
Scarp
Post by Scarp » Thu Oct 05, 2017 2:05 pm
write them like 5 times yesterday I got a reply sorry we need a car to make a soft for the 2,5 N52 so no kit yet available . That was directly from ESS
Chris1981
Post by Chris1981 » Thu Oct 05, 2017 2:12 pm
[/quote]
This is the same as I've read in my research for more power out of the N52B30 (without spending £5k+ on a S/C)... the states have 325/328 that run a de-tuned version of our (UK) 3.0si, they all seem to switch out the inlet manifold for the one we get as standard! Using the inlet manifold is well known BMW trick for restricting power, pity is the 3.0si already gets the best BMW produce! Presumably fitting a 3.0si manifold to 2.5si will give a bit more power on the E85, good news for those on here with a 2.5si! :thumbsup:
Curious as to how you get a dual DISA valve set up working on a car that's only designed to run 1 though... would you have to splice another connector into the ECU?
E86 Coupe 3.0si Sport - Montego Blue, Pearl Grey with Piano Black dash
BC BR series Coilovers, powerflex bushes, 15mm spacers, Custom SS exhaust, CDV delete
