Dropping rear centre console door
Hoping for some help from anyone who's had this issue. In the past someone has taken the door that allows access to the cd changer/ satnav DVD off and now it is only partially damped so tends to hit the centre console when opened. Does anyone know how you get the damping to work. I can take the door off, but what do you need to adjust/ fix to reinstate the damping. Ps it's got the plug in phone module so would ideally like to do the repair in situ if possible.
Thanks in anticipation
Sterling Grey 3.0i E85 Black Heated Leather M sports seats , 224's ,Sat Nav, Bluetooth, Xenons, PDC, Gaptech ,Cruise and a nice warm garage. NOW GONE
Silver 3.0i Z4 NOW GONE
- hopz121
I am not too sure what you mean buddy, do you mean the strap limiting the drop of the door has failed?
Some pics may help
Some pics may help
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
I guess so as when you push the button to open the door to access the DVD OR CD autochanger the drop drops a couple of inches slowly then speeds up ( and makes a funny noise) My previous z4 just dropped slowly .
- srhutch
- Moderator
Can you not repair it then?
So had a little play with today and seen a small hole on the drivers side of the door and also found someone talking about inserting a small rod or spoke into the hole before removing the door. Obviously this was not done by the previous owner and I think that's why the door is longer damped. Can you retention the door? Car had Bluetooth so getting a replacement door may be hard and expensive.
- srhutch
- Moderator
Bluetooth shouldn't make any difference, except you need to buy the right door. The cradle just pops out so fitting isn't an issue.
As said they come up on eBay quite often.
I have the same problem with a second hand door I got on the bay. My original was fine but the finish was peeling off so I swapped it. New one was fine for a while then started clicking before giving up, it now has no damping. This weekend I split the old one open to check out the mechanism, will add photos tonight. I can't quite figure out how the fault was caused and fixing might be difficult. The flap only splits open destructively.
Here's the mechanism, if they break I can't see how you can fix them. Just make sure a pin goes in the hold in the side if they are ever removed.
- WP_20171028_11_43_38_Pro.jpg (183.23 KiB) Viewed 1369 times
What's the white bit Steve.i am trying to work out if it's just damped against the spring. Also mine has the Bluetooth module on it so I need to know if that part could be migrated to a replacement door.
No way you can get that out without mashing the whole door, I could seal it back up but to prise it apart you end up mullering the edges all the way around. The white bit is just a solid plastic piece, I *think* it's the spring that does the damping.
Either way, if the door doesn't work as advertised, I can't figure out a way to get it back in from the outside.
