Clay your glass !
- patriot66
Clay your glass !
Whilst claying, glazing and waxing my Zed yesterday I noticed small particles of fallout adhered to all the exterior glass. I normally use wire wool to remove glass contamination but thought I would give this a try. I got myself a small piece of 3M Fine Clay, lathered up the glass with Wurth Active Glass Foam and worked round in an up/down & side to side pattern. The result is quite amazing...the cleanest, smoothest, shiniest glass ever ! Give it a go !
Clay your glass !
Great tip ,never considered it but that should bring a screen back to life as you say
2007 Z4 3.0 si Sport Auto Monaco Blue Roadster / 2013 X1 2.5d Auto M Sport White
1st BMW a 2002 when they were current ..! and wife has a 2014 Mini Cooper auto
All BMW family
All BMW family
- buzyg
- chapeau
Clay your glass !
I'll give that a try next time the clay bar is out
E85. 2.5i SE. 2004. Sterling grey, anthracite 107s, black leather heated seats, hardtop, sound gen retrofit, matt black grills, stubby, zhp, cupholders retrofit, roof motor in boot.
- Swiftly
Clay your glass !
I have been claying my screen for the past 4 years. When I first read about doing this on another forum, I was dubious to say the least. However it is quick and so easy to do and makes a world of difference, so don't hesitate, just do it
Online
- patriot66
Clay your glass !
Just PM'd you again mate.jamesditchy wrote:I need to get some cleaning tips from you Si when we're up in Galloway
Online
- patriot66
Clay your glass !
No problem mate.jamesditchy wrote:That would be great. Appreciate that
Clay your glass !
Clay should be demoted as its use increases. So paint work -> glass -> wheels.
- jakblade
Clay your glass !
Bit concerned if I was to do this to my windscreen it would fill the multitude of small stone chips with clay. Like it has done on front of bonnet...most annoying..
2004 2.5,clear fronts,sides,rears,stubby.Self quad conv+rear bumper, Aero's,108's,spacers, cruise, mfsw, 3.0l brake conv,m-tec discs.Modded Z4M bumper
Clay your glass !
I think you may be pushing a little too hard with the clay piece, Jak!jakblade wrote:Bit concerned if I was to do this to my windscreen it would fill the multitude of small stone chips with clay. Like it has done on front of bonnet...most annoying..
- jakblade
Clay your glass !
Hhmmm. Suppose I could be. Can be a bit ham fisted at times...JAD wrote:I think you may be pushing a little too hard with the clay piece, Jak!jakblade wrote:Bit concerned if I was to do this to my windscreen it would fill the multitude of small stone chips with clay. Like it has done on front of bonnet...most annoying..
Clay your glass !
I think I will give this a go as I can hear the contaminants when the wipers sweep
