2008 Z4 coupe
Jackthehat
2008 Z4 coupe
Post by Jackthehat » Fri Aug 18, 2017 7:26 pm
Just to annoy :poke: sorry :( my Z4 is a roadster and Pre facelift, I didn't realise the lighting changed in its operation for LCI... :cry: :cry:
Fixit
2008 Z4 coupe
Post by Fixit » Fri Aug 18, 2017 7:53 pm
I'm sure the halo in my lamps only lights up on the out side lamps but I will check them when it goes a bit darker I'll take a picture, how do I post pics on the forum
Fixit
2008 Z4 coupe
Post by Fixit » Fri Aug 18, 2017 8:36 pm
Just gone through the lights on my car it has auto lights if you turn the switch 1 click to the left, then back to zero off 1 click to the right inner halos on 2 clicks to the right inner halos stay on and outer bizenon light up put main beam on it adjusts the angle of the bizenons, and still no inner lights for main beam, and when I turn the lamps out back to zero on the switch when I flash the lamps with the stalk only the outer lamps flash :wink:
Fixit
2008 Z4 coupe
Post by Fixit » Fri Aug 18, 2017 8:40 pm
Lamps
Lamps
Lamps2
Lamps2
Fixit
2008 Z4 coupe
Post by Fixit » Fri Aug 18, 2017 8:56 pm
I like this little switch
