Roof cover
Roof cover
I've purchased a cover for my soft top to stop the rain getting to my roof motor.. as I've only had the car 3 weeks I don't know wear the water gets in so if anyone can help it would be very much appreciated... thank you
Roof cover
Hope this helps
- Roof cover
- Screenshot_2017-06-28-12-24-15.png (632.78 KiB) Viewed 1314 times
- Ducklakeview
Roof cover
That may stop water getting down there, but do you only use it in the dry, and never wash it? Also, it's 14yr old car, so chances are the motor will be wet...
The water permeates the outer layer of the roof, it then runs over the inner rubberised waterproofing layer, and is directed down into the drains, which is where the motor sits.
Mike
Mike
- Marlon
Roof cover
Pity the designers at BMW didn't have that revelation!Ducklakeview wrote: ↑Wed Jun 28, 2017 1:05 pm
Mike
(mind you they got pretty much everything else right, so they're forgiven)
Gone: 3.0si 2008 E85
911 997 Carrera S
Roof cover
thank you very much Mike
Roof cover
I cover it every night and if I take it to work I cover it. the drain holes are they easy to get to.
- Marlon
Roof cover
I'd get it relocated to the boot - as Mike says, chances are its swimming in water already. Several members provide that service at very reasonable cost including Mikejayjay1971 wrote: ↑Wed Jun 28, 2017 2:02 pm I cover it every night and if I take it to work I cover it. the drain holes are they easy to get to.
The exit holes are here, there are bungs that you pull out to see how much water, sludge has collected over the years, but regardless of what comes out the motor can still be sitting in a puddle:
[IMG]http://i1301.photobucket.com/albums/ag1 ... 21sj7p.jpg[/IMG]
911 997 Carrera S
Roof cover
top man thanks for your help
Roof cover
mike how much would you charge to do that for me.
- Ducklakeview
Roof cover
If the motor is currently working, the cost to get it moved to the boot and covered (doesn't take up any usable space) is £80 including an oil top up. Takes about 35 mins.
Mike
Roof cover
I live in Ipswich......lol.... you live in Liverpool
- volumex65
Roof cover
I live in Southampton , and drove up to mike (ducklakeview) , also had my aircon regassed, all for less than £150 and a day out , well worth it
I had seen quotes of around £500 - think it was well worth the day out
You don`t need a parachute to skydive - you only need one to do it for a second time
Roof cover
looks like me might be having a day out.... thank you all for the advise
Roof cover
how long did it take you to get there ..............................
