New Member from Germany
Welcome, loving the calipers
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
How do you rate the exhaust compared to the standard one? Do you get any droning noise at cruising speeds around 120kph
Thanks. For me it was important to get more performance on the brakes. But that they are good looking is also not that bad
It is much louder now because the middle part are only strate pipes, and yes there are droning noises at round abou 2000 to 2200 rpm. For me it is standard in the meantime but if you want to have it a little less droning you have to drive at rpm above 2200.LordOxygen wrote: ↑Sat Jun 24, 2017 6:20 pmHow do you rate the exhaust compared to the standard one? Do you get any droning noise at cruising speeds around 120kph
I think the best way in case of performance and sound is to modify an standard exhaust professional. Because the chance is very high to end without droning.
Regards
Sven
