Re mapping
Online
Mr Tidy
Re mapping
Post by Mr Tidy » Thu Oct 26, 2017 10:07 pm
jamie_z4 wrote: Thu Oct 26, 2017 10:41 amdefo consider a remap - the N52 seems to be one of the few NA engines which respond well to a map. I had my 2.5i (177bhp) mapped to 200 bhp! Which I was astonished at.
Actually from what I can make out the facelift 2.5i is the only E85 engine that does respond well to a remap. Probably because the 2.5Si was pretty much the same engine but rated at 218bhp - I'm guessing because of BMWs original mapping!
As Marlon said you might get 15 bhp on a 3.0Si, but if they are required then why not? :(
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
PinkPineapple44
Re mapping
Post by PinkPineapple44 » Thu Oct 26, 2017 10:36 pm
I will probably get my nasp 3.0 N52 mapped in the foreseeable future; mainly for the removal of flat spots, improved engine response and the ability to turn off all the DSC nonsense whilst also engaging sport mode.
Ducklakeview
Re mapping
Post by Ducklakeview » Fri Oct 27, 2017 12:07 am
PinkPineapple44 wrote: Thu Oct 26, 2017 10:36 pm I will probably get my nasp 3.0 N52 mapped in the foreseeable future; mainly for the removal of flat spots, improved engine response and the ability to turn off all the DSC nonsense whilst also engaging sport mode.
Seriously, don't waste your £... If your car has flat spots a "remap" will probably exaggerate them. Find the problem rather than try and have it mapped out.
Mike
idej_z4
Re mapping
Post by idej_z4 » Fri Oct 27, 2017 7:43 am
Totally different question, and maybe one for another thread, but I'm planning to put the Z on a rolling road to see how many horses have escaped...is there anything that can be done to get lost horses back?
Once the Z isn't a daily anymore (next winter) then weight shedding will be my main focus for extra speed. :driving:
ph001
Re mapping
Post by ph001 » Fri Oct 27, 2017 7:48 am
The only reason it could be down on power would be things like:
Blocked filters
Low quality fuel
Worn plugs
Low compression
Air leaks etc
If you have no fault codes stored, are on top of the servicing and use super unleaded there is no reason for it to be down on power.
PinkPineapple44
Re mapping
Post by PinkPineapple44 » Fri Oct 27, 2017 8:00 am
Ducklakeview wrote: Fri Oct 27, 2017 12:07 am
Mike
There's no problem, the factory maps are always a compromise. My e36 328 was night and day after a remap. But even if there is absolutely no gain and BMW did a perfect job, I still want all aids off whilst a sport mode is on.
idej_z4
Re mapping
Post by idej_z4 » Fri Oct 27, 2017 9:34 am
ph001 wrote: Fri Oct 27, 2017 7:48 am The only reason it could be down on power would be things like:
Blocked filters
Low quality fuel
Worn plugs
Low compression
Air leaks etc
That is good to know - thanks! I can tick 3 of those off the list. Only low compression and air leaks could get me. I only use V Power and are completely on top of servicing as well. :thumbsup:
Chris1981
Re mapping
Post by Chris1981 » Wed Nov 01, 2017 2:53 pm
I had a remap as part of an exhaust package... whether or not the power has increased I couldn't say as like Marlon there was no rolling road used but the throttle response was certainly improved and after 3.5k the engine was far more response than pre-map! (Potentially also due to the increased throttle response!)
I had no flat spots before the map and if you think having a remap would cure any you're wrong ph001 and DLV are 100% right on that one... these engines also have numerous sensors that will become less efficient over time and although they may not throw an engine code may contribute to flat spots.... Camshaft sensors, TPS and MAF to name but a few, I cleaned my MAF properly recently and I certainly felt a difference, the wire was caked in black crap so easy to tell it wouldn't be reading air flow correctly!
A remap would be worth considering if you are making other mods such as exhaust or intake, as you are changing the way in which the engine breathes and the standard map may actually cause a reduction in power so if you put on an induction kit or remove cats a remap would be more beneficial.... I will be changing my 3.0si intake in the near future and plan on having a rolling road tune so will post following that with some dyno prints hopefully!
E86 Coupe 3.0si Sport - Montego Blue, Pearl Grey with Piano Black dash
BC BR series Coilovers, powerflex bushes, 15mm spacers, Custom SS exhaust, CDV delete
chrisgreen
Re mapping
Post by chrisgreen » Thu Nov 02, 2017 5:17 pm
I had a remap on my 2.2i Z3. I did have a full exhaust system and sports cats but the remap was worth it. Even though I never had it on a dyno the engine felt so much more lively and power came in much earlier in the rev range. It was a 2.2 so was never chasing numbers!!
also the rev limiter was raised ever so slightly which was nice on those occasions when I did rev it up to the max. Obviously if you redline every gear change then I wouldn't recommend but for every now and again it was fun.
I've always taken the view that it's down to how the car feels - if it feels faster/more urgent and better to drive - then 99% of the time that's good enough unless you're regularly doing track days and standing 1/4 miles.
'04 E85 Z4 3.0 silver/black - daily driver :driving: - Sold
'02 E46 M3 PY/Kiwi
'05 E46 330d Touring - Silver Grey/Black
